I have a Mercruiser 888 (Ford 302) with cooling problems. The first day I took it out the engine didn't get up to any temperature but the manifolds got real hot. So the next day I do some investigating and found that there should be a separation plate between the elbows and the manifolds. So I got the block off plates and installed them. Now the motor gets REAL hot and the manifolds are also still hot. So here is what I did to troubleshoot:<br /><br />First, unhooked the line coming from the stern drive pump and ran it a little bit with the water muffs. Flow was great. Took off the inlet and outlet lines to the manifolds and ran water through them. Flow was great. Ran water through the exhaust elbow. Flow also seemed to be great there. <br /><br />I have replaced the engine water pump and the thermostat, and I have not noticed any water in the oil. At this point I am at a complete loss as to what it could be? <br /><br />It seems to be running great, is there any what that the timing could be off far enough for it to overheat and yet still run good? <br /><br />I will take any suggestions at this point! Thanks.
