totorunner
- Aug 13, 2010
- 12
Hey all,
I have a 1997 glastron gs180 that stalls on hot startups. It cranks up fine the first time when it is cold and runs normal. However, if I shut the engine down for either 5 minutes or an hour it stalls when putting it in gear and trying to takeoff. They only way I can get it to go is by free revving it several times and then planning up as quickly as possible. Once she gets going it is fine once again. I can stop, let it idle and takeoff again without issues.
If I turn it off for a few minutes it will do this again. What is the issue?
Also my tachometer does not work. When I turn the boat on the needle moves some but does not read anything. The info center lights work normally though. Not sure if this is related by I figured I would kill 2 birds with 1 stone and fix both!
Thanks in advance
Thanks in advance
