Re: The Johnson Curse continues...
"It finally got to the point tho that it was too rich to run and I had to put the stock jets back in."
Why did it get richer over time? Something changed. Are you running ethanol? Hope not. Do the floats still float? Maybe they are soaked up a bit.
I actually have ran very little ethanol gas. I am lucky enough to have 2 stations where I live now that are ethanol free. Where I use to live, one station was ethanol free up until the last few months I lived there. For the most part it has all been ethanol free gas. When I have had to run ethanol fuel I only buy enough to burn it up within the week and I always add seafoam or stabil.
For the recirculating valves. I checked the old ones and had a couple that were missing the screens and a couple that were some what "sticky" so I replaced them all when I rebuilt it. I did find a hose that had a cut in it after installing them, but that was fixed when the problems first started. None the less I will double check them again. I haven't checked the reeds, I will do that asap.
Ran great before the rebuild, ran great until I put the thremostats in. The owner before me never ran it with thermostats unless it was cold outside. Then I made abot a 6 mile run and was idling into a pocket and the #3 wrist pin came out, never been like it was afterwards. It has ran fine at WOT and ran fine at an idle since the rebuild, but not necessaraly at the same time. There has been a problem between idle and WOT the whole time since the rebuild. Generally a stumble/bog/stall when going from idle to WOT, which seems to be from the carbs "loading up". Idle for a few seconds you can hear it and see the rpms drop until it cuts out. If you do not idle or rev it up it will plane out without stumbling or bogging. It has been supressed to the point at times it was tolerable, but just seems to get worse and worse.
Yes there are fixed jets. Currently there are the stock idle and intermediate and the .002 larger high speed installed. I ment adjustments on the idle mixture screws.
Model is J200STLERK
