Re: identifying my 33hp johnson outboard
If the model year follows the RXEL format, its not a 1969. That was the beginning of the hp/year format for model numbers. A 1969 33hp Johnson would be 33E69A, 33EL69A, 33R69A or 33RL69A model number.
Your motor would be an RXEL-13 (1965), RXEL-14 (1966), RXEL-15 (1967) or RXEL-16 (1968). If the midsection is Forest Green, its probably a 1968. If its white all over, it would be one of the other years.
There isn't any significant difference in parts between the years, that I can remember. You should be able to buy just about anything you need, just knowing that it is a '65 - '68 motor.
Post a pic of the motor here is you can. Be sure to show the cowl from the side, fron & back. If its the original cowl, we might be able to tell the year, just from that.
