1955 15 hp evenrude
Daviet
Re: 1955 15 hp evenrude
If you are talking about the shift lever, you have to remove the powerhead to gain access to the shift rod attached to the end of the shift lever.
jokar
Thank you for responding, i appreciate it.
You are correct, i do have to remove power head, that is what i need help with.i have no idea how to do this.
Please help.
Thank you
Daviet
It's not as hard as it looks, remove the throttle linkage from the tiller handle and then the powerhead bolts. the thing that may give you a hard time is frozen bolts.
Do you have and OEM manual, might be a good idea to get one and do some reading first.
jokar
Thank you much.
No i have no manual, where can i get one cheap?
How many bolts hold power head on?
Thank you again, god bless
samo_ott
I have the parts manual that will show you what's there. send me a PM with your email address and your request if you want it.
