Like the post says, I'm adding a battery barrel switch to my 1980 Jetster with a Mariner 115. All it has to kill the power is the ignition key. I have the switch itself and a piece of battery cable with lugs on either end so I'm ready to install. My question is, do I put the switch on the positive or negative side? Also, can I still run the memory wire for the stereo to the battery and not create some sort of loop where everything just feeds through the stereo and draws energy through that one wire?
Thanks in advance,
Scotty
Thanks in advance,
Scotty
