Have 1984 60 hp 3 cyl Mercury. It started fine, but would stall & quit as if turned off when accelerated past 1500 rpm. Bought manual & set timing and other adjustments. Removed carbs and blew them out. Put in water, had same results. Reset all adjustments again and backed into water. Outside temp was 95 deg. So engine parts were some warm. It started right up. Ran about 5-10 seconds and quit. It would not fire again. Connected timing light, NOTHING.
Pulled home and rechecked with timing light. No flash or spark. Tried this couple times. It did flash eractically couple times. After outside temp cooled down it started, but only ran a few seconds.
Just for fun I strapped an ice pack on the switch box & laid one on top of fly wheel. Waited about 10-15 minutes. Motor fired right up and kept running.
Does anyone have a suggestion?
