Johnny Be Cool
- Jul 22, 2010
- 126
Looking for a ballpark figure on how much will it cost to replace head gaskets on a 1990 5.7 Mercruiser / sterndrive. Reason I ask, I'm still trouble shooting and would like to tget an ideal of one of the possible worst case senarios.
Previously had water in cyl and pan. Cleaned it all out, started motor on muffs, temp went high both attempts. I did after each run a compression, oil and cylinder check. All good. I did notice the exhaust manifold leaked a tiny amount of water above the casting mark where the bolt hole is. I thought maybe not enough water under muffs, took it to the lake and the fuel pump went. It did try to start it using starter fluid, it started then died as if it was lack of fuel.
I took it to a Mechanic, it's been there for a week just sitting, I'm next in line Monday. I hopeing that it's not a cracked head or block. Worst case, head gasket or maybe impeller or flaps??
Who knows!
Who knows!
