Hey guys,
I recently changed my plugs and made the mistake of going with champion plugs. When I pulled the original plugs (AC delco) I noticed and was VERY surprised to see the gaps between .043 to .048.
I called my local boat mechanic and and researched online. All i found and told was .035 gap and went with it.
Although the boat runs OK, I have noticed a decrease in engine performance with the new plugs. It's the only thing I changed. Cap/rotor/ plug wires were all good.
Everyone told me Champion was GARBAGE. I picked up some NGK 3754's to replace the Champions. Now I am trying to figure out why the original plugs appear to have been gapped at .045
The engine is a 2000 VP 5.7L GS (NOT GSi) PEFS engine code. It is a carb motor NOT EFI. I do believe it has the vortec heads as it uses the longer plugs.
The NGK 3754 is the cross for the AC,autolite, and champion plug.
I am considering just gapping them to .045, approx where the AC plugs that were in it were gapped. It was running GREAT before even though the plugs looked liked they needed to be changed.
If it's not broke don't fix it, I know! I was just trying to be pro-active and give her a tune up.
Any have this same motor setup with any thoughs?
thanks for reading...
