Re: Video Question, Maybe very bad issue!!!!
Yacht Dr. I did not put those braces in at all LOL the PO had put those in to suport a carpeted solid feeling un-fiberglassed PT deck!!!! he had sold this boat to my friend for a few grand and he didnt knwo better and thought it was in amazign shape...i knew better and he gave me this project for FREE
I don't think the transom will be that hard..the hardest part in that area is the part that sticks outside off the main transom where the engine mounts...its about and inch thick at bottom and 3/4 on top..not sure how to cut ply at an angle LOL... unless i make a false skin and seacast that one little part...
if you look at my original Dr. the entire transom was completely rotted and most of it turned to dirt....alot of the inner skin of glass was brittle and broke off in my hand...in fact I cannot even walk on the original stringers because they start to break under my feet.
i plan on making the transom a good 2 - 3" thick...the outboard i'll be using doesnt have a max transom thickness as the bracket just mounts flush with the top of the splashwell.
I plan on doing a little extra reinforcement when I do put the transom back in...you'll notice that the wood part of teh transom stops about 5" below teh cap at that weird protrudig angle..I plan on grinding back a bit on all side and tab out pretty far from the transon wood to make it a bit stronger.
I also plan on adding a center line below deck fuel tank under the deck...so i would have to beef up that entire area anyway....
anyone have a thought on secasting just that small portion of the potruding transom? or should i glass in some ply and build over that.
