I changed the water pump impeller and now the gearcase will not seat all the way back on the leg. It goes all the way on except for a 1/8''. When I tighten the 3 bolts that hold it on the gears start to bind and the prop is hard to turn by hand. I removed the drive shaft and the gear case seats all the way with no effort. The shaft appears insert properly in the gearcase end. I also put the shaft in the powerhead end and it appear to insert all the way. When I try to put it back together I still get the 1/8'' of gap and it binds once I tighten it.
btw- When I first removed the gearcase to replace the impeller the drive shaft was stuck in the power head end. I had to put vice grips on it and hit out with a hammer to remove it. I have since cleaned the splines and it inserts and removes without effort into the power head end.
Any help or ideas?
Any help or ideas?
