reavesga
- Feb 14, 2010
- 163
I am currently running a 1973 OMC 140 HP OMC Stringer Sterndrive. It has run fine for two seaons now after about a $1000 investment in the ball gears, bearings, and a water pump. Last Friday it "slipped" out of gear. Turned out it was the shift switch. A frantic google search turned up omc-switch.com where you can get the switch rebuilt. Expensive though. Also found one on e-bay which is installed right now and will hopefully get me through the weekend. Anyway this got me thinking about parts availability and cost. I have a complete 1974 Mercruiser MC-1 that is in good shape. A lot of folks have said I need to swap the MC-1 in as parts are still available. What I want to know is; is the swap is worth the trouble just to get a Mercruiser drive?
I have the problem of the large OMC hole in the transom solved. Boat is Aluminum transom plate can be bolted in and out so building up a new transom is not a big deal. It looks like the hardest thing on the job is going to be just physically moving the engines around as I don't have an over head lift that can reach up into the boat.
Would love to hear from folks that have contemplated the same issue. If you have done this swap, what problems / challenges did you run into and were you happy with the result?
