i just bought a '68 model 39. first thing i did was drain the lower unit grease as well as take off the lower unit to inspect the impeller. the grease, which had been in the lower unit for just a few minutes while it ran in a 55g drum, was milky. and there was some grease in the water pump area. i pulled the lower water pump housing and there was water around the inner seal. are the seals factory installed into the lower housing? the seal had the flat end with the numbers facing out....so the lip part was pointing towards the impeller.
second thing is the notch for the impeller key is wide, but the key looks like a needle bearing, and looks like it fits the impeller. is this the correct key?
