Hi all! Im a new guy, first time posting. Ive spent a bunch of time searching these forums in hopes of finding answers to my questions, but I cant seem to find them, so i figured Id post to see if someone here can kindly help.
Im looking to convert my 2bbl Mercruiser v-8 to a 4bbl, and I have a few questions, and am trying to find a part number too. Here goes:
Boat is a 2000 Rinker captiva 232
Mercruiser 5.0L I/O, w/ 2bbl carb
Vortec heads.
I am installing:
edelbrock 1409 600 cfm carb
Edelbrock Performer EPS intake
Questions are as follows:
Does anyone have a part number for the linkage bracket at the carb base? I cant find anything suitable in online parts houses, etc. Not sure what to ask local shop for (i.e. year, etc)?
Currently have a PCV hose running from port (Im assuming its referenced as sitting facing forward?) valve cover into base of 2bbl carb. However, the eddy 1409 doesnt have a pcv provision. Do I need a carb spacer with a PCV port? Or where do i run this to?
On the starboard side, about 1/3 of the way back on the current manifold is a brass flex tube that connects to the starboard exhaust riser. Is this an egr? If so, to where does it get routed on the new manifold? I thought I read somewhere in a post here that the riser just gets plugged and this tube is not reused? Is that correct?
Is there a merc part number for a fuel line that will bolt up to this? ( a longshot, I know, but I know merc has used weber carbs in the past, but not sure if with elec pump?)
What are the odds that the carb jetting will be close-to-good-enough out of the box?
I know I have to ground out the ign module (T-Bolt 5) to get base timing set - any other tricks or "gotchas"?
Please let me know if I left out any key info. I would GREATLY appreciate any and all responses - I have a lot of experience restoring/rebuilding cars, and a lot of experience boating, but not much experience rebuilding boats!
Thanks!
Ron
Vortec heads.
I am installing:
Thanks!
Ron
