buckwheat34
- Jul 29, 2010
- 36
Just picked up a Force 50 on a Blue Fin fishing boat and ran into a problem, it will not start. Had a little sputter on the second turn of the key and nothing since. Checked fuel from the tank to the filter, filter to the carb, pumped tank ball and no problem, got fuel. I'm getting fuel when I put my finger in the carb opening. I also checked the spark plugs and I have spark when cranking the engine. When it wouldn't start initially, I pulled the plugs and they were wet and a little black. When cranking the engine to check spark with the plug removed, cylinder expells what looks like fuel. DUmped some fuel into the cylinder and still would not fire. Had spark before and after I added the fuel at the cylinder. Vent / screw on gas tank cap open or closed makes no difference. After cranking the fuel ball is a little soft and appears to move a little fuel, 1/4 squeez of ball then firm again, What gives? Am I missing something here? Any suggestions other than dynamite?
