I have a 1996 pro sports ff1800 nada has it at 900lbs net weight. It has a 1999 dt 140 efi. It also has a 6" back set jackplate. it also has trim tabs. i'm not sure what all info you need to help me out. The boat had a 1996 dt 115. I puthe the prop off of that engine and put it on the 140. It is a 4 blade ss but I can't find any name or #'s on it. The problem i'm haveing is when I try to trim the motor out it sucks air befor I can get it trimed out. with the 115 I could hit 44 mph on the gps at 5000rpms. now with the 140 i can only do about 35 before it starts sucking air. this is with the jackplate all the way down.
What would be a good prop to use on this boat. What size and pitch. I have to stay with ss
Thanks for the help
Thanks for the help
