13starsinax
- Jul 26, 2010
- 13
hello there,
i need some of the wisdom i have been coming to this site for in the past. ok, my motor has movement when you grab the lower cowling you can move the whole motor every thing as one piece not just the cowling or motor itself forward and back roughly an inch to inch and a half. movement that is not supposed to be there.. ive looked at schematis and i see the rubber mount upper it does look very rough and not like the diagram the bolts come through the upper mount and into the arm shaft assembly with the rubber not fully covering the bolts. when i removed the exhaust housing cover front i see the drive shaft and there is no bushing around it and there where rubber parts lose in that area, and i cant find a diagram reflecting that there should be one there...the shift rod that goes through the lower cowling has a gasket or bushing around it to that does not look real good but i can not really get a good look at it with the motor together..so where is this play comming from? please help with any ideas and i will keep a good watch to awnser you back..thank you
