Re: Where is your fire extinguisher?
Any possibility I could get you to take a pic of this? I kinda like the sound of it.
Just picture an over sized rod holder mounted to the side of the foot well or gunwale.
In my case I took a 6' length of 4" PVC Schedule 40 pipe, through drilled it, with two holes, the inner holes are countersunk so they don't dig into the extinguisher. I have on mounted on a 45 degree angle to the left down support on the foot well on my one boat, and one mounted the same way but down below the gunwale, attached to the seat box on my aluminum Starchief. I also like to have one at the rear, near the motor and fuel tanks, usually near the point where you enter or exit the boat. On my Starchief, I have a small bording ladder that stows away within the starboard gunwale or storage bin, the fire ext. is just under the splashwell on that side. That way if I had to get to another boat on the water with it, or had to deal with battery fire, it's right there.
I keep one in both locations also because there's always the chance that you can't reach or get to the other in an emergency.
