Re: Adding speedo to boat.
ok the boat speedos work like this for the most part
a thing called a PITOT...it mounts to the bottom at the back transom....has a little hole in it ....a small tube connects....it goes all the way to the dash...the speedo works from the pressure of the air inside the tube...the water comes into the tube a little bit...and pressurizes the air...causing the speedo to show speed etc...
FYI it is definitely different than a car speedo....
a volt meter is super dandy....shows battery and charging voltage etc
engine water temp VERY GOOD TO HAVE!
a tach is even more useful than a speedo...shows RPMs...so you dont blow up yer motor! lol speed is relative! ( I do like to know my speed tho)
an oil pressure gauge is good to have.....or atleast an idiot light....
some people have trim gauges, though it is handy its not necessary...you can
feel trim once you get accustomed to boating......shows the angle of the outboard or I/O outdrive....
mebbe a compass if you go out in big water...(ocean/great lakes etc)
GPS is handy...your cell phone might have one too...works! (Iphone-etc)
fuel gauge....should have for med to large boats....little tiny boats dont need em...they mostly use 5-10 gallon tanks with primer bulbs etc....
