Tahoe 55
- Jul 15, 2008
- 226
I have a Merc. 5.0 MPI with a Alfa with 62 hours on her. The boat is 2 years old. At the start of this season I notice a "ticking" sound coming fron the engine at idle. It sounds like an exhaust leak "tick". The noise changes with RPM. As you advance the throttle, it gets louder and faster until normal engine noise over comes it. Seems to be louder when the engine is cold and seems to be coming from the starboard/aft side of the engine and low. I've crawled all around looking for exhaust leaks and can't find one. I can't get back and down far enough though to inspect the area where the noise seems to be coming from. There isn't any water coming into the bilge and if the exhaust was leaking that far back, I would think water would be leaking out too. I tightened all hose clamps anyway though.
When My wife 1st pointed out the noise, I though it was normal and it had always been there, but it seems to be getting worse as the season goes on. All gauges read normal and the engine is fine on power. After I couldn't find a problem, I'd been ignoring it, but as it seems to be getting worse, I think I need to solve whatever the problem is.
Any ideas or suggestions?
