Ok, I got it to run right, it's a 115hp in line 6 1978 merc. if you are in back of the motor there is a small hose sticking down and out of the right side. is that supposed to spray water out of it when you are running along? or is that a bad thing. I'd like to know what that really is.
Second, twards the top of the driveshaft exhaust tube section there are 2 square holes in the back (lower case not the gearcase) do these serve a purpose?
Starting, I read that they start hard when cold, the correct way is to give it full throttle-up/warm -up with the choke on until it starts? or is there a better method? it seems like it cranks for a good 90 + seconds and then some before it speesd up and wants to go, I am wongering if I am doing something wrong?
Thanks,
Dave
Thanks,
Dave
