Upstatehunter
- Apr 27, 2010
- 41
Was having trouble at WOT, would die out. Place I bought it from said probably the fuel pump and changed it. Same thing. Pulled the bowl off the carb to see an old float, flaking the coating off it. Read that super glue or tank seal will coat ok until the new one comes. Coated it and put it back together. Cleaned everything in the high speed jet. Questioning no kind of spring on the needle valve? Most I've ever worked on had one. Have seen a few smaller HP motors without on just sat on the float arm. Now the gas runs out of the carb when I pump the bulb...
