new to boating but mechaniclly inclined. just pick up 90 bayliner capri 150 hp force outboard promplem is tilt trim not working. motor is spinning losssened front hydra line bottom of motor fluid coming out when trim pressed motor does not move unit does build pressure. drained and changed fluid no movment. fluid does move from front facing line witch goes to valve body then fluid from valve body to return line in bottom of motor. from my thinking it should work fluid making complete cycle through system but motor does not move on it own. if it put a stap on motor get in the boat and put pressure on motor it seems to pull down but if i let go of stat it is like there is no pressure in cylinder to hold up motor. the guy i got boat from said he had someone do something to the system so the motor can be moved up and secured with a stap so he could get it out of water last year. i am at my wits end . im sure it something simple i just cant aford to throw money at it any ideas would be great thank you
