Hello All,
I have an issue with my (new to me) 70hp. Carbs were just synchronized, new plugs, timing good, cables adjusted yet after running a few minutes on flush unit I get a pretty big puddle of thick black oil out the prop exhaust. Lower unit oil is golden brown & clean. Could this be carbon buildup in the cylinders from either not being winterized or running too rich prior to me getting this engine? or sitting for about 2 years prior to me owning it? It started to sputter & saw the smoke, then wouldn't start up right away, put in New plugs again, ended up soaked & black so changed plugs a 3rd time & am just waiting for this to drain before trying to restart the motor. It idles fine & sounds good until it fouls the plugs...p.s. even compression mid 140's & mixture it perfect 50:1. I am guessing engine was sitting awhile & maybe carbon build up is burning off...Any ideas?? thanks.
