I am looking into swapping a complete 302 into my sea ray for the 305 that is seized. However rather than swapping just the engine, i am swapping everything. I am not talking about hooking up the ford engine to the drive unit that is currently in the boat. I can grab a complete system including engine, outdrive, and transom unit from another boat. I would be doing a COMPLETE swap from the engine all the way to the outdrive. Pretty much swapping the hull i guess!
My question is this, is this reasonable because i have heard that the 302 ford system uses a different bolt pattern on the transom and a ford sterndrive unit will not match up to the existing gm one.
Is this true or just a line of bs? Are there any difficulties that i would run into? Remember i will not be using any existing parts, basically taking everything off one boat and putting it into the sea ray.
I appreciate any advice.
