So we have a 3.0 merc that has had issues starting. I read all the sticky's but have a question. When I jump a wire from 12v to the + on the coil the thing fires up super fast.
We swapped out the solenoid to a different one that was working, it will start, but not nearly as fast as when the jumper is attached. It does eventually start, but it takes a few more tries. Is this normal? Or is my solenoid sticking?
One guy I talked to said to jump the two smaller terminals on the solenoid and call it a day. Will that do damage? I know that connecting a jumper from a 12v source to the + coil will burn points, but I think that terminal with the yellow/red only has power when you are starting right?
