johnbell47
- Jul 1, 2008
- 34
I have 7 hours on my mercruiser inboard, converted from a 898 merc, 305, newer center rise manifolds, E bay items. I had absolutely no trouble with the engine. I was taking on a little water in the boat and could not detect any from the rudder packing or shaft packing, so I really am sure it is not a hull issue. So, I figgered that the engine had a little leak, putting water in the hull. (this was about 10 gallons in 4 hours, or just enough for the bilge pump to pick up. ) I capped the exhaust thru hulls with rubber test caps and then pressured up the system on the water hose, which is about 65 psi. I had checked the oil before start and was about 1/2 quart low. Long story short, the engine is now full of water. Coming out the valve covers..I think I know what happend but want educated opinions.. Thanks in advance.
