Re: Piston Wrist pin Cap question on Force 150hp 1992
I will see if I can find my tool ( Not that one, I always know where it is) and post a photo
Hey Frank,
I used a 7/8" open ended wrench for removal and installation.
Just finding one with a jaw thickness of between 0.295" and 0.310" was the trick. Found one in a flexhead/open end combo that was perfect.
Now, I have another issue that has kept me up for the past three nights.
After doing the vasoline trick with the 16 bearings for the third time I have a big question.
Should the cages be able to freely rotate all the way around the journal?
The only example of a force con rod I have is the adjacent cylinder and it can completely rotate.
The two manuals I have state the needles should be free and have no binding issues when you spin the crank by hand.
The cracked caps are in perfect alignment, but I have just snugged down the cap screws. Didn't want to possibly wreck a good con rod in the process. Could tightening up the screws to spec. help the rotation?
Is there a wrong way to place the cages?
Is the cage rotation important to the journal life?
Am I being too particular?
After an overheat on the top cylinder due to the impeller, I have rebuilt the pump and re-sealed the lower end, replaced the starter and now the broken top ring on cylinder #1 this '89 150hp Force has had me loose many hours of sleep. Having decades of experience in automotive rebuilding, this only my second marine outboard and this one has been an experience.
This project has been going on for 2 seasons.
Any opinions from the Force experts on the rod bearings?
Regards,
*wrenchead*
