Re: 1980 johnson 70hp bogging
Wally,I agree that your problem seems to be fuel related.But.Im curious as to the help you have been getting up to now.As said a 1980 wont be VRO,wouldnt be fuel injected and .As for carbs.When they are dirty ,the require total disassembly.There are small passages that get plugged from old fuel/oil varnishing.As well as the jets.You need to have them soak in a carb cleaning solution.Depending on how bad they are will dictate if you need rebuild kits.The needle and seats can get bal ,gaskets often dry up,you should pull any plugs for the cleaning and the replacements come in the kits.You also mention the primer .Primers provide raw fuel to be squierted into the manifold .This is in lieu of the older butterfly choke.A 1980 engine would have a butterfly choke system,it would operate with the key in the same fashion.I m curious if its possible your engine has a new cowl/cover that might say VRO ,or maybe you just have the yr wrong.Hope the info helps.If not ,come back ,try and find any identifyinf info you can
