Re: 1987 150 HP V6 'Cooling Issues?' Update!
John and others.
I replaced the rubber grommets in the tank caps. They were both there but very hard and mis-shapen. I took the valve out of the side of the motor before checking to see what my brother had gotten me. It was the wrong one, so I looked it over and put it back. I fired the boat up and got the air out of the oil delivery line (YAHOOO) by bleeding it full of fuel, then running the motor with the oil pump arm wide open (linkage disconnected). I let it run a couple minutes and then checked the pressure in the onboard tank. There was pressure.
I then ran it again as the motor tank was not completley filled up with the cap off and oil came right up and out, as soon as I replaced the cap there still seemed to be an air gap in that oil tank, but only on the rearward side. I'm thinking it can't get out because I can't lower my motor to level while doing this????
I'm going to go see if they have a check valve, and replace that, and then trim the motor down to level (I'll use a ditch once I get to our property) and try that. Hopefully I'm getting close and can enjoy a weekend of boating fun. The motor is smoking like CRAZY with all the oil in the fuel and the oil pump shoving oil into it.
