Re: Help finding a start button
Ok, now i'm even a bit more confused. Let me give you guys some more background.
I have a 1968 mercury 20hp. Right now it has everything it needs to be an electric start but the external (boat side?) wiring harness. I have found this harness but its really expensive. Right now my motor has the starter solenoid, electric choke solenoid, and the the starter itself. All hooked to the internal wiring harness.
My plan was to take out the internal harness and just run the proper wires to to the proper spots. Not knowing that I didn't know what I was doing I planned on having a toggle switch for an "ignition" switch. A push button to start the motor. A kill button (not sure if I need that or could just flip the ignition switch to off). A toggle switch for choke.
With all that explained does that make sense what I was going for? I realize that I could probably get a key switch that does all of those same things in one convenient spot. But whats the fun in that!
Is what I'm doing stupid? Will it work/not work?
If I understand you silvertip (after I read your post like 10 times; not because it wasn't right or anything...just cause I'm dumb
) There is basically three positions on the key switch for the boat motor. There is off, iginition, and start.
1. When the key is in the off position that essentially means I'm holding down the kill button? Is that correct?
2. Then there is the ignition position. That means the kill button is no longer being held down. Allowing the coils to do their job? Is this correct?
3. The start position engages the starter motor. That spins the fly wheel and starts the engine. Once the engine starts you turn the key back to the ignition spot, sort of like in a car. Is this correct?
If I understand this correctly I could get a toggle switch with an ON and Off position, that would be like the key being either off or act just like the key in the ignition position. Then I could push in a button similar to what I posted, that would only engage the starter motor. So once the engine starts I release the start button. Since the toggle switch is still in the "ON" position the engine is allowed to continue to run, until I flip that toggle switch. Is the correct?
Sorry for the long post, I just want to understand how this all works.
