OakwoodBeachBum
- Jun 19, 2010
- 12
OK, I have a 1998 J90PLEEB w/ S/N (as much as I can see on the tag): 04678765?
Symptoms: Starts ok, but dies quickly as if fuel starved...it stalls out. If I play with it, it will eventually hold idle and runs ok. Runs rich, Smokey at startup. Skips and vibrates. Seems to eat a lot of fuel versus how it used to run before. I am finding 2 cycle oil inside the cover and running down the outside. This thing was dry and tight before. Last year we had a drippy leak at the white garden hose looking connector on the fuel supply. I tightened and it got worse; the gasket rolled. My shop replaced and that stopped the leak, but still not running right like it use to. When I hit the throttle, I get some hessitation before it responds.
I just noticed the plugs looked bad today so replaced. See attached pictures. They looked oil fouled a little bit. Have not run yet since replacing plugs. Next picture I am pointing to a spot where oil leaks out.
Background: Ran fine previously. Winterized and stored for ~2 seasons while I pursued a major fiberglass job on the hull. Ran it last season with some issues. I used to get 45mph out of this thing. Now I only get 35mph. Of course, maybe boat is heavier since repaired? Top RPM WOT is 5300RPM. My mechanic says the thing is fine and is blaming on extreme hot weather making it dificult to start the motor...but I dunno. It does not run the same as it did before I stored it.
Is this an ethanol issue?
Am I losing the VRO/fuel pump assy?
Am I making a mountain out of a mole hill?
Suggestions?
Pictures show: Where oil is pooling and leaking out of motor enclosure. The spark plugs I pulled today. The motor: oil is coating everything. I have wiped down with paper towels. The white nylon connector was leaking last year. The air breather is removed in this picture... it had filled up with oil a couple of times. Wierd--one plug really corroded versus others.
Suggestions?
