mick97
- Mar 24, 2010
- 207
I wanted to check the reeds,and the float on my motor.Took off the under neath bolt,but still cant seem to get the bowl clear,so I can look at things.
I see a spring bouncing around in the bottom of the bowl.
What is that for?
Must of fell off something hu?
Or does it go over the bolt shaft where the bolt mounts up the bowl?
Boy,if I can't get the bowl off,does this spring matter?Mabe it keeps the float balanced or something hu?
How do you check the reeds?
Thanks,
Scotty
What is that for?
Thanks,
Scotty
