45Auto
- May 31, 2002
- 2,842
Re: I had a feeling I was over-propped...
I would definitely expect it to lower the RPM, but not necessarily affect the top speed. Top speed depends on how much power you're putting into the water, which is determined by where you're at on the horsepower curve for your engine. If it's a relatively flat horsepower curve (usually true with a stock big block), then the difference of a few hundred RPM will make a minimal difference in power output and little or no difference in speed. 400HP is 400HP, whether you're turning a particular prop at 4500 RPM or a 10% smaller prop at 10% higher RPM.
If you change prop styles or brands you could have even more effects (in either direction) caused by prop configuration/efficiency differences.
Hopefully it'll work out for you, nobody can guarantee it. Never hurts to have a spare prop anyway.
wouldn't you expect a change from a 23p prop to a 25p prop to drop the RPM by 200-300 RPM and knock top speed down a 2-3 MPH?
