Hi:
I just picked up the above lightwin at a flea market.
It started after adding new fuel, but there is not any apparent water coming out a weep hole. I noticed a little cut out area in the housing that said water flush and there is a screw slot plug that appears to have been removed in the past.
I observed no weep hole for a stream. Should I loosen or remove this plug to see if this is pumping water. I have the motor in a barrel with the water well up on the down tube as deep as just a few inches below the power head.
Thanks much for any assistance.
I would maybe purchase a manual later, does it require the J4C plugs as was mentioned for the other poster. Also what is the required mix. I mixed up about a 1/2 gallon of premium alcohol free gas with 16/1 ratio of some Pure Oil Outboard motor oil that I had on the shelf for the last 30 plus years. I use it in my Martin 45.
What year is this? maybe a 59 like my old aluminum 59 14' Cadillac boat??
If I need a water pump how would I go about it.
This is my first attempt at a post as I imagine you guessed.
Thanks Again.
Tom
Askov, MN
Thanks Again.
Tom
Askov, MN
