I recently bought an 89 kayd 18ft deck boat, when i looked at it it started right up. Checked the oil no milky residue (head / or cracked block issue).Which was good. I took it out once to check it out it started but ran rough . I couldn't get it to stay running. Itook it home checked the water separator and replaced it. The fuel was orange with alot of sediment. Replaced spark plugs. Was goin to take the carb apart to get all the sediment out of the bowls but i didnt'. I did however start the process removed the four bolts then removed the hose to the choke. But i reinstalled everything. I started it and ran good with the muffs. A little hesitation to throttle response but cleraed up as i let it run. Now the problem, Took it out ran pretty good had to feather the throttle to get up to speed but it stayed running. I met a friend on the lake and floated for a couple hours, went to start it and nothing. It tried to run idled around 400 rpm thn died it wouldn't go any higher. Got pulled in and i pulled the spark plugs and water in the cylinders but none in the crank. HELP!!!!!! Any suggestions THANKS!!! Happy fathers day wanted to take my kids out on the water. At least i did that part.
