I have a 2008 Four Winns H200 SS with a 5.0 Volvo Engine with 51 hours. I just had the oil and filter changed, fuel filter replaced, impeller replaced and outdrive lube changed.
Today my wife and I headed out on the lake and we were idling through the no wake zone and when I got on the throttle the boat died. I would start it up and then it would die again. I had to get a tow back in and the only way I could keep it running was by holding the key on start and giving it gas. Had to do it to get it back on the trailer.
I did hear a slight whinning noise coming from the engine compartment. The noise was coming from a cylinder next to the fuel filter (not sure what it is called). The boat has always run perfect until I had this maintenance done. Any thoughts on what could be wrong?
Thanks in advance for your help.
Anthony
Anthony
