Re: 15-20 year old boats - realistic hours
Hours only count on the engine...and that doesn't really tell you much....it could show minimal hours, but they could be hours of dragging the lower unit through sand , and ingesting sand until the impeller was chunks of rubber and overheating the engine...just forget about that silly meter and really look at what you are considering to buy. If the boat has nasty vinyl and carpet, guess how much attention was paid to the engine...look at the engine bay , if it is an I/O,and it is filthy , as in 'something leaked' thats a good indicator of how it was mantained...whatever was replaced , only happened AFTER it broke....not after thorough inspections...and thats just the engine...I have just finished removing at my best guess, around 500 lbs of water-logged 'flotation foam ' from the bowels of my boat , EVERYTHING it contacted (wood) was SOAKING wet.....as was the foam...
Each boat is different, it all depends on how it was stored ( indoors vs. outdoors and uncovered)and how it was mantained.Good luck in your search ,and look hard at whatever you see before plunking down any cash....
