ugadawg187
- Aug 18, 2007
- 165
Okay so the the motor will run but not idle. You have to open up the throttle to get it to crank & keep it goin. As soon as you back of the throttle it dies. Sometimes its kind of sluggish about going when you throttle up, it kinda sputters a bit but then kicks on up & seems to run fine. The other thing that has me scratching my head is that it will only run 4000 rpm at WOT & sometimes the rpms drop down to 3200-3500 while at WOT but it does not sound like the motor idles down at all when the rpms drop so thats prob a tach issue right?
Ive been told it could need the following:
1. carbs cleaned/ rebuilt
2. stator
3. trigger
4. rectifier
Heres a pic of some bad wiring on the motor that goes to the switch box. I believe its the trigger wires but not sure so let me know if im wrong. (black/white wire)
2. stator
3. trigger
4. rectifier
