Re: Engine upgrade?
Along with the above you will need exhaust manifolds, and a ton of other parts that you wont know of until you need them.
Well, I don't think you'd need a "TON" of other parts.....you would need new manifolds and a different drive.
A lot of your accessories would swap over. The V-6 is very similar to a 350.
I had a quick look at the alternator brackets (Doug Russell parts)for an 89 V-6 vs a V-8 and it appears that even the alternator brackets and starter motor are the same part number.
So your main difference might be the wrong ratio drive. Your drive is worth as much as any other Alpha drive for a V-6 and SBC v-8 so you could probably sell yours and easily find the right ratio OR just get a NEW SEI drive with a 3 year warranty.
I would do it. Don't get me wrong though, It's not completely a bolt/plug/play change but it's pretty close!
Cheers,
Rick
For example, the flywheel housing for an 89 4.3L V-6 is the same as that required for a V-8.
