Pulled the gear housing off my 290A DP to access the bellows and water intake fitting. I replaced the two O rings, put everything back together and now cant get it to go into forward or reverse. I also now have water in the upper unit. I checked the gear linkage and believe I hooked everything back up correctly. I read in one of the posts that there is a seal in the upper unit that keeps water out. If so, could someone verify this and tell me where the seal would be? Also, any ideas on what to check for the shifting issue? I'm guessing I didnt put something back correctly because everything was fine before I pulled the upper housing. Thanks for any ideas!
