The situation is that I have a 23? quest with twin 91 150?s I purchased the boat three weeks ago. The problem is that I can match the engines at 3300 RPM and run all day but when I run over 3500 the starboard engine gets the steady alarm and retards to 2500 RPM I can shut it down and start it right back up and it will run at 3300 all day again I can run the engines up to 5500 RPM and take a hole shot with great power both but after a minute if I don?t bring the starboard engine back to 3300 RPM I will get the alarm the VOR is disconnected wires and all and the alarm is steady not a beep I have changed the thermostats water pumps and used a thermal gun to check the temp of the heads and they all run around 150 degrees I have ran an auxiliary fuel tank right to the starboard engine and still have gotten the problem. Please any help or suggestions are greatly appreciated.
