jplbrenn@comcast.net
- Jun 9, 2010
- 1
I have a 1979 Evinrude 100 hp. The tnt will go down when the switch is pressed but will not go up. I took the motor off of a boat and put it on another. In the process I disconnected the wires in the junction box. I did not try the tnt before I removed it from the other boat. I believe I have the wires connected properly. I have tested the tnt motor direct to a battery and it works fine. I have tested the switch on the control handle and it works. I have tested the wires for breaks (ohm meter) and they seem fine. If I bypass the relay (there is one of them) I can run the tnt up. How do I test the relay? What else can I look for as the problem or test. Thanks, John
