I saw a 2.5 block which had the entire exhaust system ported. The exhaust ports weren't enlarged, just everything from the port had been removed and polished. The (what I would call) exhaust flow directors (from each cylinder) had been ground out and smoothed into the larger exhaust flow channels. From there it looked like they had flowed the entire system by removing and polishing everything that may create exhaust flow restrictions as the exhaust flows toward the tuner.
I know changing the tuners can either help or hinder a particular set-up. But what will this type of exhaust work provide or hurt?
Thanks,
Thanks,
