Kainon
- Sep 13, 2009
- 608
Re: I'm an owner! 1975 Islander 22
I put my inline 6 into my boat without any lifting device, I had a house deck that was 6'6" we put the the short block " without cylinder head" on the deck and slid it into the boat on a 2"x6" or 2"x8" Plank. then moved it around by hand.
You may still get the engine fixed, but the engine needs to be removed from the boat, so you can remove the oil pan and get at the crank shaft.
a 4 cyl block without the head i think weight about 150lbs, if you can take the intake/exh manifold off, the head off you can then muscle the short block onto the boat deck, flip it over, unbolt the crank and you'd be about 50lbs lighter.
Also think about if you know someone that has a Fork Truck
and If you remove the tires from the trailer, you can more easily use a Rented or Borrowed Engine hoist.
Maybe ask a local auto repair place to remove the engine, bring it with everything ready to go (hoses, wires etc, detached).
then put the engine into the back of your vehicle...
??? Some ideas. I know if I was there i'd be able to free up the pistons.
but if severly rusted, the block needs to be removed from the boat.
good luck.
good luck.
