Re: Carb question
Taking a long time to warm up might be an indication of problems with the thermostats, like maybe one or both stuck open. You'd have to pull the thermostat covers to check each 'stat. You'll need new gaskets once you pop open the covers, unless they come off cleanly and you can properly re-seal them.
This could also be a reason for the poor fuel economy, these motors are designed to run at a certain temp and will idle real bad if too cold. 10-15 minutes is quite a long time for warmup.
The block and heads should get warm-ish, not real hot. The exhaust manifold cover should stay cool to lukewarm.
I'd imagine a stuck water pressure relief poppet might do the same thing, so you may want to check that out, too.
Oh, Boy, more things to check, Yay!...........ed
On the spark plugs, check your manual. If it specifies Perma-Gap plugs with no alternative then that's what should be used. Perma-Gaps run colder than standard electrode-type and use of the wrong heat range electrode-type plug could cause destructive detonation.
