Hey guys getting ready to glass the stringers, frames and floor back in. Things are pretty much ground down to where I want them just need to clean up and wipe down with acetone.
This will be my first time ever using polyester resisn and fiberglass and have one small question.
I have a good 1/4" gap around the floor to hull joint except one section that is about 12" long where I have anywhere from 1/2" to 1". Not cutting a new section of the floor so was wondering what is the best way to span this gap. I know I will need to create a putty and make fillets around this edge before I put the final fiberglass sheath on.
If I make a thick putty mixture will I be able to work this gap or span this gap?
