Re: cracked cylinder head
While it is possible to have cracked a cylinder head, your heads and cylinders are one piece and cast as part of the block with sleeves in them. The piece your thinking is the cylinder head is just a cover and even if its weeping water out the spark plug holes it would not be the source of water intrusion.
The most common place for intrusion to occur on the IL3 and IL4 is the exhaust plate on the side of the engine.
On the off chance that you did crack a cylinder head you'll need to tear the engine down and have it welded.
