tilt steering column
slowroller88
I have a 1995 Chris Craft 21" concept BR. My Tilt column has worn out, but the helm unit is still good. I cannot fing the MFG of the column & helm unit. I pulled the column and the only markings it has on it are the numbers: # 6626.
I check the helm unit and can see where the MFG sticker once was, but has long ago fallen off.
I was wondering if anyone may have some advice for me to identify the PN# to order the tilt column.
Thanks in advance!!
seabob4
Re: tilt steering column
Slowroller,
Does your tilt helm look like this one?
If so, I have a brand new one...
slowroller88
Mine is similar, but I don't think it is the same. I will take a picture now and post.
slowroller88
Here are some pics of the column removed from my boat.
Hopefully these will help
seabob4
Does the underside where the shaft on the helm underneath your dash attaches to the tilt mechanism look like this?
Mounting holes are 3 3/4" apart. This a new Teleflex unit, P/N 91500.
slowroller88
the measurement from outside edge to outside edge of the bolt holes is 4-3/4". Here is mine from the steering shaft side. Note that the shaft has a slot that the cross-bolt rests in. The pen is just to hold the little coupler up where you can see it.
seabob4
Very similiar, but not the same. Oh well, back in the box she goes...
seabob4
Slowroller,
If you can PM me some full size pics, I have a good friend at Teleflex/Canada that could probably identify it for you, if it is indeed a Teleflex tilt unit...
slowroller88
Seabob,
I'm at the office now, so all I have is the camera on my phone.
I will take some better full size pics when I get home and send.
Thanks for your help!!
seabob4
Will check back later for the pics. Marc knows his sh!t, I have another contact there...
slowroller88
Here some better pics of the column I have.
slowroller88
I spoke w/ Teleflex ( thanks for the link Lrider!), and was advised that the unit I have is a Morris, which is obsolete. I am going to try and find a new / gently used replacement column, as the cost of retro-fitting with a tilt column is way more than the budget allows.
I would appreciate any ideas on where to look outside the norm.. ( ebay, CL, etc.)
Thanks agian for the advice!
