Down to take the stress off the transom and enough to drain it fully. If it's outside in the winter it's tucked all the way down and under so water doesn't accumulate and freeze in the hub.
If you consider 'not in use' to mean the boat sitting at the slip, then I would say it's up all the way.
If on shore, it's all the way down.
So with it up you could get some dirt built up on the shafts, So when you lower the motor down the next time, the dirt could catch on the seals and damage the seals,
All the way down so I can get the boat in the garage.
another FYI - this is a mercury sub forum. Mercury uses ATF. ATF has additives that shorten the life of rubber and high hydraulic pressures will accelerate the demise of your trim systems internal organs. More important than whether you are up or down is that you block the engine and/or release the pressure when in storage. Just make sure the last thing you do is a bump on the switch in a down direction. It will add years to the life of your trim system.
